Hello all. I am trying to code something that guides my robot to face the goal when I press a button. The code gives an attribute error, but I am not sure what that means. My code is as follow, and the error is apparently on line 64. My controller is named controller_1, my motors are left_motor and right_motor, and my vision sensor is named vision_sensor. It is coded in Vexcode V5 Python.
#region VEXcode Generated Robot Configuration
from vex import *
import urandom
# Brain should be defined by default
brain=Brain()
# Robot configuration code
# vex-vision-config:begin
vision_sensor__SIG_1 = Signature(1, 835, 1877, 1356,-6023, -5067, -5545,3.7, 0)
vision_sensor = Vision(Ports.PORT10, 50, vision_sensor__SIG_1)
# vex-vision-config:end
controller_1 = Controller(PRIMARY)
left_motor = Motor(Ports.PORT1, GearSetting.RATIO_18_1, False)
right_motor = Motor(Ports.PORT3, GearSetting.RATIO_18_1, False)
# wait for rotation sensor to fully initialize
wait(30, MSEC)
#endregion VEXcode Generated Robot Configuration
# Project: VEXcode Project
# Author: VEX
# Created:
# Description: VEXcode V5 Python Project
# Library imports
from vex import *
# Begin project code
TARGET_CENTER_X = 160 # The desired center x position of the target
KP = 0.08 # The proportional gain for the PID control
KD = 0.12 # The derivative gain for the PID control
# Initialize error variables
last_error = 0 # The previous error for calculating the derivative term
# Initialize drive and turn variables
drive = 0
turn = 0
speed = 0
# Initialize loop flag
run_loop = False
while True:
if controller_1.buttonX.pressing(): # If button X is pressed
if not run_loop: # If the loop is not already running
run_loop = True # Start the loop
else: # If button X is not pressed
if run_loop: # If the loop is currently running
run_loop = False # Stop the loop
if run_loop: # If the loop is running
# Take snapshot and find largest object
vision_sensor.take_snapshot(vision_sensor__SIG_1) # Take a snapshot with the vision sensor
# Calculate error and PID output
if vision_sensor is not None: #If a target is detected by the vision sensor
error = TARGET_CENTER_X - vision_sensor.largest_object().centerX # Calculate the error between the target's center x position and the largest object's center x position
speed = error - last_error # Calculate the speed of change of the error
pid_output = error * KP + speed * KD # Calculate the PID output using the proportional and derivative gains and the error and speed
last_error = error # Store the current error as the previous error for the next iteration
else: # If no target is detected by the vision sensor
pid_output = 0 # Set the PID output to zero
# Get joystick inputs and calculate drive and turn values
drive = controller_1.axis3.position() * 0.12 # Get the forward/backward joystick input from the controller and scale it by 0.12
turn = controller_1.axis1.position() * 0.12 - pid_output # Get the left/right joystick input from the controller and subtract the PID output from it
# Drive robot
left_motor.spin(FORWARD, drive - turn, VOLT)
right_motor.spin(FORWARD, drive + turn, VOLT)
I am grateful for any help. A competition is coming up, and thats why Iām so urgent.
