definately worth experimenting to make your own means of an expanding intake. the concept is great… just a little fine-tuning to fit your design should be used…
I’ve seen teams use 4 axles (on the outside of the intake) in a plus configuration connected by some sort of metal structure. as the objects push on the metal above the intake, it lifts up and the axles form walls on the outside keeping it within the newly formed cage.
You have the option of lift up the exending oart
And dropping them in.
Our strategy is to add all the match loads into
our ntake and then put them in the 30" in
autonomous.
I dont hink that would be a problem.
uve got a solid idea going there, but if ur looking to make the most effecient bot possible, ur gunna wanna slap some motors on those slides to help them out. they wont b missed o ur lift of drive.
I dont think you guys get what imean.
I just want a part that will extend up by the barrels and ball pushing up against it and let gracity bring it down.
that is one of the most crucial parts of the bot! i would recommend using (4) 393s for that (in that case you could have your name plates on there too…
i never get side tracked… and it is important so teams know what color alliance you are and your team number. the judges and refs also like to know this information!!! that is why it is important.
something else i found that works nice, if you take a nice solid steal c-channel and cut out all the metal in between all the holes in the middle line, you can put one on each side of ur intake and if u put a bolt attaching the modified c-channels to ur intake so you have a nice smooth rigid expanding box.not to mention smooth as a baby’s bottom.
