I was curious to see if I could extract *.vex files and insert additional tabs myself since the VCS Tab manager isn’t released yet. I didn’t figure out how to do that, but I did discover by using an online file type checker that the VCS files are really tar files. I changed the file name and extracted it and was met with a single file named “ThIsisATemPoRaRyFiLE.json”. Here is what the json for my VEX C++ project contained:
{"title":"Programming Junk","description":"Justin's useless junk","version":"0.0.1","icon":"USER000x.bmp","competition":true,"files":{"robot-config.h":"dXNpbmcgbmFtZXNwYWNlIHZleDsKdmV4OjpicmFpbiBCcmFpbjsKdmV4Ojptb3RvciBNb3RvcjEgKHZleDo6UE9SVDEsIHZleDo6Z2VhclNldHRpbmc6OnJhdGlvMThfMSxmYWxzZSk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzEgKDEsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzIgKDIsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzMgKDMsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzQgKDQsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzUgKDUsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzYgKDYsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uOjpzaWduYXR1cmUgU0lHXzcgKDcsIDAsIDAsIDAsIDAsIDAsIDAsIDIuNSwgMCk7CnZleDo6dmlzaW9uIFZpc2lvbjEgKHZleDo6UE9SVDExLCA1MCwgU0lHXzEsIFNJR18yLCBTSUdfMywgU0lHXzQsIFNJR181LCBTSUdfNiwgU0lHXzcpOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR18xICgxLCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR18yICgyLCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR18zICgzLCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR180ICg0LCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR181ICg1LCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR182ICg2LCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbjo6c2lnbmF0dXJlIFNJR183ICg3LCAwLCAwLCAwLCAwLCAwLCAwLCAyLjUsIDApOwp2ZXg6OnZpc2lvbiBWaXNpb24yICh2ZXg6OlBPUlQxMiwgNTAsIFNJR18xLCBTSUdfMiwgU0lHXzMsIFNJR180LCBTSUdfNSwgU0lHXzYsIFNJR183KTsKdmV4OjpneXJvIEd5cm8xKCBCcmFpbi5UaHJlZVdpcmVQb3J0LkEpOwp2ZXg6OmFjY2VsZXJvbWV0ZXIgQWNjZWxlcm9tZXRlcjEoIEJyYWluLlRocmVlV2lyZVBvcnQuQik7CnZleDo6Y29udHJvbGxlciBDb250cm9sbGVyMTsKdmV4Ojpjb250cm9sbGVyIENvbnRyb2xsZXIyKCB2ZXg6OmNvbnRyb2xsZXJUeXBlOjpwYXJ0bmVyICk7CnZleDo6Y29tcGV0aXRpb24gQ29tcGV0aXRpb247","main.cpp":"I2luY2x1ZGUgInJvYm90LWNvbmZpZy5oIgogICAgICAgICAgCgppbnQgbWFpbigpIHsKCn0g"},"device":{"slot":1,"type":"vexV5"},"language":{"name":"vc++"},"components":{"name":"Controller1","class":"vex::controller","left":439,"top":51,"type":"controller"},{"name":"Controller2","class":"vex::controller","left":757,"top":17,"type":"controller"},{"name":"Motor1","class":"vex::motor","port":"1","left":11,"top":376,"type":"motor","data":{"gears":200,"reversed":false}},{"name":"Vision1","class":"vex::vision","port":"11","left":331,"top":379,"type":"vision","data":{"brightness":50,"signatures":{"name":"SIG_1","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_1"},"range":2.5},{"name":"SIG_2","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_2"},"range":2.5},{"name":"SIG_3","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_3"},"range":2.5},{"name":"SIG_4","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_4"},"range":2.5},{"name":"SIG_5","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_5"},"range":2.5},{"name":"SIG_6","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_6"},"range":2.5},{"name":"SIG_7","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_7"},"range":2.5}],"codes":]}},{"name":"Vision2","class":"vex::vision","port":"12","left":572,"top":376,"type":"vision","data":{"brightness":50,"signatures":{"name":"SIG_1","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_1"},"range":2.5},{"name":"SIG_2","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_2"},"range":2.5},{"name":"SIG_3","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_3"},"range":2.5},{"name":"SIG_4","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_4"},"range":2.5},{"name":"SIG_5","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_5"},"range":2.5},{"name":"SIG_6","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_6"},"range":2.5},{"name":"SIG_7","parameters":{"uMin":0,"uMax":0,"uMean":0,"vMin":0,"vMax":0,"vMean":0,"rgb":0,"type":0,"name":"SIG_7"},"range":2.5}],"codes":]}},{"name":"Gyro1","class":"vex::gyro","port":"A","left":853,"top":411,"type":"gyro"},{"name":"Accelerometer1","class":"vex::accelerometer","port":"B","left":1047,"top":400,"type":"accelerometer"}]}
