Everytime I try to download using the EZ template code, it gives me this message:
“You’re about to upload 595964 bytes wirelessly. This could take some time, and you should consider uploading directly with a wire. [y/N]:”
I download with a wire and if I say yes then it just it just says uploading and is stuck like that.
Output:
Transferring V5 to download channel
Uploading program “MainBranch” (MainBranch) to V5 slot 1 on COM8 (compressed)
Compressing library
Uploading 1W2NmZXcf0xK76cYY633Sw
ERROR - pros.cli.upload:upload - ClearCommError failed (PermissionError(13, ‘The device does not recognize the command.’, None, 22)) - pros-cli version:3.4.1
We detected something went wrong! Do you want to send a report? [y/N]:
