I use VSC, and every time I try uploading it says that I’m uploading a huge amount of bytes wirelessly, but when I connect it to the brain directly with a wire it is just stuck on uploading. What do i do?
If you have any logs, it would be helpful to see them. Other then that try a different port on your computer, a different computer (if available), or a different brain (if available) to help troubleshoot. Check if a empty pros project is able to upload to figure out if the issue is specific to EZ template, or if it’s a general pros issue.
