EZ-Template Files Not Working
I tried to install the latest version of Ez-Template, but I keep getting file compilation errors, does anyone recognize these error codes?
Not sending analytics for this command.
Creating cold package with EZ-Template,libc,liblvgl,libm,libpros,okapilib [ERRORS]
c:/users/berrygar000/appdata/roaming/code/user/globalstorage/sigbots.pros/install/pros-toolchain-windows/usr/bin/…/lib/gcc/arm-none-eabi/10.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: unrecognized option ‘–no-warn-rwx-segments’
c:/users/berrygar000/appdata/roaming/code/user/globalstorage/sigbots.pros/install/pros-toolchain-windows/usr/bin/…/lib/gcc/arm-none-eabi/10.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: use the --help option for usage information
collect2.exe: error: ld returned 1 exit status
make: *** [common.mk:242: bin/cold.package.elf] Error 1
ERROR - pros.cli.build:make - Failed to make project: Exit Code 2 - pros-cli version:3.5.4
PROS-CLI Version: 3.5.4
PROS-Kernel Version: 4.1.1
± Error ---------------------------------------------------------------------+
| Failed to build |
Hi, are you still having trouble with this?
