I am trying to use the 75MHz Signal Splitter, and it appears to have failed. The failure mode is unusual, it just passes the power from the battery to the motors, and the motors just run. The signal from the radio transmitter has no effect. Is there a fix like a reset of some kind? If not I will just buy a new Signal Splitter. Any comments including similar experience would be appreciated.
Not sure how much luck you’ll have asking here, not many people still use them. I would contact VEX as they should be able to help troubleshoot or repair it. http://www.vexrobotics.com/vexedr/contact/
Thanks Kevin, I did see a post from a few years ago that said it was cheaper to replace the Signal Splitter than to repair it. I just found that I have a spare so I will give it a try. I do have a controller but it is in use in another model.
