Hey!!
We are trying to update the firmware of our Cortex and we are receiving the following message from RobotC. Have tried to look for a solution online but nothing works. Im running the latest Robot C version.
Well, that means that ROBOTC cannot see the cortex serial connection for some reason.
Make sure that the cortex is connected using the USB A-A cable, see if the cortex shows up as a “port” in the windows device manager.
If you are trying to update the cortex master firmware you can also try using the “VEXnet Firmware Upgrade Utility” found here.
https://www.vexrobotics.com/vexedr/resources/firmware
If your firmware is already up to date, try and do a “software inspection” from the robot menu and see what that shows.
