We have experienced multiple fan failures on the same two Victor 884’s this year. Each of these Victors supplies one large CIM motor on our drivetrain. We have gone through 5 fans combined on these two. We’ve had no other problems with our power system. Only the fans are failing - the Victors continue to work fine. We have checked and re-checked our wiring and all is proper. We have 4 other Victors on the robot and none of their fans are failing.
Be sure you have at least 2" of clearance above the fan for proper air flow. You should not operate the Victor without a fan. Please call 903-453-0802 for RMA # if you would like for us to evaluate your failed fans.
