Fence Rack Clearer Pros + Cons
Okay so I had a sort of unique idea for my team’s dumper robot( I attached the file at the bottom), and i was wondering if this is really worth it. In autonomous/first 30 seconds of the match I feel as if this could help a ton for the early clearing of the fence racks, but after that I think it would just get in the way and limit the robot’s maneuverability. Ideas? Thoughts? Opinions?
this team did it, and since its elevated, it probably wont get in the way as much, and it also helps with throwing
If you switched to a claw design (not saying you should) then if your arm can get high enough, you could have the claw double as a fence sweeper. Just saying.
