Trying to cad a plastic climb hook for our cnc machine, but missing some measurements for the actual bar. Specifically, I need the measurements labelled in the drawing attached below.
Specifically, I need the width of the bar at the widest point, and the height of the entire bar
Any help is appreciated
Looking at the field specs appendix in the game manual the height of the bar seems to be 2.03 inches. Subtract the heights in the image to get that. For example, 18.16-16.13 = 2.03. As for the width of the cross section of the bar you can grab the field CAD and use the measure tool or just try to measure it on your real field.
Grab the CAD from VEX’s website under resources: VRC (2024-25) Full Game & Field Element Kit - VEX Robotics
Thanks for that. Ill do that now
