After the most recent update with tournament manager…
Upon startup, at random, Tournament manager is assigning the Servers ip address (.150) to a field rack (Pi 4B). All displays and field racks should be in the .151-.199 range. After startup the issue will follow the pi if you switch it around. if you shut down the entire server rack and reboot, the problem can start with a completely different pi or sometimes not at all. Theoretically a workaround is just to keep a backup pi to swap in and out whenever this happens but that is a very annoying and unprofessional fix.
I have attempted to isolate the problem in many ways with no conclusive end in sight.
I have swapped pis
i have swapped servers
i have swapped networks
computers etc.
It seems to be completely random
