I am looking for ideas for a field riser for an IQ field. I am not looking for anything wood as this is in a basement and don’t want it expanding. I have thought about metal bed frames but I have seen screw heads bumping over the frame which would make the top uneven. I’m not looking to spend more than $100-150. I’d like to keep it around 14-18”s off the ground. Any ideas/sources? What do they use at competitions to raise fields?
You can also check out the commercial risers from Robosource.net
You might want to consider 5-gallon buckets and a couple sheets of OSB.
We use the ones in the plans above…but we’ll probably switch to the “portable robosource risers” because we need 3 more and I don’t have time to build them. At worlds, it’s commercial staging…well past your budget.
I saw a colleague use the plastic storage racks you can get from the hardware store; they only put them together one high and then put them together. I would say, they would move if you leaned on them, probably ok for practicing, but not good for competition.
