when i try to open the file it wont open. i have tried other files and they work. all build, src, vex, and include files are there, but it wont open
does anybody have a solution to this, i need my code to open, i have a backup, but the auton is not perfected yet
Really not sure how VEX files save information. But can you open the file in notepad or another text based programming application? (make a copy first incase that does further damage).
they have their own file type that is “v5code” and i have not found any other app that opens it up.
.v5code is I believe just a file that tells that application how to open the other files. @jpearman would probably know
The actual code files are in the folders project/src and project/include
The .v5code file is just some JSON with info about the project and its files.
One option – you should be able to open src/main.cpp
(as well as any other files you edited in the src
and include
directories in another program (notepad++, VS code, etc.) and copy their contents into a new project in VEXcode Pro V5.
If you can’t open the source files at all, even in some other text editor, then you have more complicated problems.
i opened the main.ccp, and it was completely empty, i think that means that i am not getting that file back, but i do have a built file of it, do you know if there is a way to derive the code from a build file?
You can not turn compiled C++ back into your original code. There might be some programs that turn it into something that does the same thing, but all variable names will be lost.
