I’m working on coding a firing mechanism and I am running into some issues. I need to have a motor (called Fire in the program) turn 30 degrees, or 30 tics on the encoder (called Encoder in the program) it is attached to at 30 power, wait 500 ms for the ball to roll out, then turn backwards the same number of tics at the same speed. I thought of doing while loops of if else statements, but all of them ended with the motor going back to 30 power as soon as the motor started to turn backwards. Any help would be appreciated. Thanks
Try
SensorValue[Encoder] = 0; // clear encoder
while(SensorValue[Encoder] < 30){ // while the motors have moved less than 30 degrees
motor[Fire] = 30; // move motor at 30 power
motor[Fire] = 0; // turn off motor
wait1msec(500); // wait 500 mlsec
while(SensorValue[Encoder] > -30){ // while motors have moved less than -30 degrees
motor[Fire] = -30; // move motor at -30 power
That’s pretty similar to stuff I have tried but it looks like it will work thanks!
