Firmware updating
It says to plug all devices in to update, but I have more devices than ports. Can you do 2 sessions?
edit. Tried unplugging one device and adding a different device and it seems to update ok. It says everything is up to date.
However, It has one bump switch attached and the Updater does not see nor acknowledge it. Have a second bump sensor and it doesn’t see it either in a different port.
Hi Steven57,
Yes, you are correct in that you can update VEX IQ sensors/motors/Controllers in multiple sessions if they are too numerous to connect to a Robot Brain all at once.
The Bumper Switches do not have any firmware to install or update, so they will not be visible to the VEX IQ Firmware Update Utility.
Regards,
  • Art
