First Line of autonomous
OK so I started writing a autonomous program for our robot and it cam up as Error:Undefined procedure ‘setMotor’.
what is the first line of autonomous program supposed to be
i am using ROBOTC for VEX® Robotics 4.0
this is the code so far
#pragma config(Motor, port2, leftDrive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port3, topLift1, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port4, topLift2, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, rightDrive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port7, bottomLift1, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, bottomLift2, tmotorVex393_MC29, openLoop)
#pragma platform(VEX2)
#include “Vex_Competition_Includes.c”
void pre_auton()
task autonomous()
setMotor(port2,127);
setMotor(port6,127);
delay(1850);
AutonomousCodePlaceholderForTesting();
task usercontrol()
while(true)
int r2=vexRT(Ch2); //drive
int l3=vexRT(Ch3); //drive
motor[rightDrive]=r2;
motor[leftDrive]=l3;
if(vexRT[Btn6D])
motor[port3]=127;
motor[port4]=127;
delay(150);
else
motor[port3]=0;
motor[port4]=0;
if(vexRT[Btn6U])
motor[port3]=-127;
motor[port4]=-127;
else
motor[port3]=0;
motor[port4]=0;
if(vexRT[Btn5D])
motor[port7]=-127;
motor[port8]=-127;
delay(150);
else
motor[port7]=0;
motor[port8]=0;
if (vexRT[Btn5U])
motor[port7]=127;
motor[port8]=127;
else
motor[port7]=0;
motor[port8]=0;
while (true)
you would write code in the autonomous task the same way as in usercontrol task.
motor port2 ] =127;
motor port6 ] =127;
delay(1850);
setMotor is an undefined procedure, ie. there is no function called setMotor.
