Flex wheel questions
  1. How do you guys keep your flex wheels clean?
  2. Should I cut flaps on mine?
  1. I mean you can just clean occasionally it with a wet cloth or something idk.
  2. that depends. Cutting notches or flaps into flex wheels can give them more compliance and more traction, but it also reduces the smoothness of the wheel as well as permanently effects the wheel.
I recommend rubbing alcohol as it will get rid of any oils that collect on it.
Test without flaps first, then decide. It varies from design to design.
