Hello everyone. Our team is debating if we should use a hinge system for our flip out or the Axel bearing method. What do you guys recommend? Thank you!
All of these talk about some pros and cons, but it is the general consensus of vex people that screw joints are better for this.
First off, how wide is your tray? Please give pictures, and also, use plates or even c-channels for custom screw joints. If your tray folds backward, then you can use vex hinge pieces. If not, then a screw joint on the side of the tray will suffice. If you have to, look up 448x’s easy design (the documentary) for inspiration to see the concept, but do not copy thier design, as making your own design is a good learning experience. Good luck on your tray. Use counter sink screws if you have a skin…
With all of the two bars this year would a screw joint be able to handle the weight or do you need a high strength shaft
How are you planning on joining your four bars, RD4Bs, six bars, etc. together? I’ve heard a lot about using screw joints with nylocks, but that proved to be incredibly static and required much effort to move. Is anyone using axles? Any help is much appreciated!
Is it okay to use axle joint instead of the screw joint for the part where the lower part of dr4b meets the tower?
Could you post some pics? That would be helpful.
Vex hinges are known to be wobbly which is why most people opt to use screw joints. They have to be built well though, or they too will be wobbly.
system
Closed
November 12, 2020, 5:05am
5
