Hello, my friend and I are trying to build a very high power vertical fly wheel, for fun. We currently have the gear train set up for 1:96. We power the train with 3 v5 motors(standard) and we get just 100rpm with them without or fly wheel attached and I have removed most friction. I’m just wondering is 100 rpm the best we can get from the motors? Do we need more motors?
I am no expert, but from my personal opinion, I would add alteast one more motor, and make sure you have a ratchet to let the flywheel spin somewhat without contacting the motors after the motors are shut off. I would hate to see a perfectly good batch of V5 motors smited from the strain of a flywheel made simply for fun.
And most importantly, if the result is good, im sure I speak for all of the vex forum when I say that we would very much like to see a video of the result.
Thank you
My team currently has a 15:1 flywheel on 200 RPM V5 motors. We’ve been working on it for a fair amount of time and surprisingly enough there has not been any problems with the internal gears (yet). Sometimes it feels like the motors themselves have a way to coast/deaccelerate rather than stopping immediately.
Back on OP’s question:
They should be able to spin faster than that at max power. Try and look for other sources of friction (i.e. gears on metal contact, more than two bearings on a drive shaft).
@Gameoa I will have a ratchet on the fly wheel once I hook the gear train to it, for now I’m running it without the actual wheel attached to it. I have looked for any metal on metal contact and I’ve made sure there are washers on them to reduce friction. I will be adding that fourth motor. Thank you for your input.
I will try to add a few more bearings around the longer shafts. Thank you for the suggestions and help
96:1 ?!
Haha…i dont even want to be near it… lol…
Hey man you gotta go big or go home lol
Getting too old to b adventurous. Lol
It’s my last year so I want to go out with a bang
If you have the motors, you might as well just stack up a bunch of them. You can get more power to turn a higher gear ratio.
Hopefully that bang isn’t your robot exploding, as cool as that would be.
If you make it to worlds, think there is a chance that you can hit the flag at NGF field from NASA field. Lol
And it’s the answer.
If we’re trying to build a super-flywheel, then why not use a bunch of brains so that we can add even more motors from more battery sources. You could snipe someone from the stands at finals at that level.
