Flywheel pid motors stop below 600 rpm
const float kp = 2;
const float ki = 0.5;
const float kd = 2;
float targetFlywheelSpeedrpm = 500; // put desired rpm flywheel speed here
float desiredMilliVoltage = 10000;
float flywheelVelocityrpm;
float error = targetFlywheelSpeedrpm - flywheelVelocityrpm;
float lastError = 0;
float totalError = 0;
float finalAdjustment = error * kp;
float flywheelPowerVolts;
int autonPIDFlywheel() {
while (1) {
if (wantToShoot) {
 flywheelVelocityrpm = (flywheel7.velocity(rpm) + flywheel8.velocity(rpm)) / -2;
 totalError += error;
 printf("error: %f \n", error);
 printf("Flywheel: %f \n", (flywheel7.velocity(rpm) + flywheel8.velocity(rpm)) / - 2);
 if (std::abs(error) <= 5) { // 0-5 noise rpm?
   readyToShoot = true;
   Controller1.rumble("-");
   printf("HERE HERE HERE: %f \n", (flywheel7.velocity(rpm) + flywheel8.velocity(rpm)) / - 2);
 else {
   readyToShoot = false;
 flywheelPowerVolts = ((error * kp) + (totalError * ki) + ((error - lastError) * kd))/12;
 flywheelPowerVolts += (desiredMilliVoltage / 1000);
 flywheel7.spin(reverse, flywheelPowerVolts, volt);
 flywheel8.spin(reverse, flywheelPowerVolts, volt);
 lastError = error;
else {
  flywheel7.stop(coast);
  flywheel8.stop(coast);
this_thread::sleep_for(20);
return 0;
Had this issue before; is there any way for flywheel pid motors to not break when it is below 600 rpm? Thanks!
unspecified, but we’d also like to know how to actually get flywheel pid motors to actually go to a desired rpm under max…
Can you elaborate a little more on what this means?
This can be done by changing your target speed. However, if you’re having trouble getting it to not go max speed you might have some issues like too high PID values.
