Hey guys
I want to make a flywheel speed control where if a button is pressed, the flywheel speed goes up in increments and if a different button is pressed the flywheel speed goes down in increments…any suggestions?
There are many examples of both this and other flywheel control methods on the forum, however, what you are describing would be something like this.
#pragma config(Motor, port9, , tmotorVex393_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
bool buttonPressed = false;
int motorSpeed = 0;
while(1)
if( vexRT Btn8R ] )
motorSpeed = 50; // Some preset speed to start
else
if( vexRT Btn8U ] && !buttonPressed )
buttonPressed = true;
motorSpeed += 5; // increment
else
if( vexRT Btn8D ] && !buttonPressed )
motorSpeed -= 5; // decrement
if( !vexRT Btn8U ] && !vexRT Btn8D ] )
// clip to valid values
if( motorSpeed < 0 ) motorSpeed = 0;
if( motorSpeed > 120 ) motorSpeed = 120;
motor port9 ] = motorSpeed;
wait1Msec(25);
