Does anyone have a decent strategy for a flywheel bot to score as many points as possible?
hey I know u
Try and work on a quick double shot. Being able to do that will be a good asset you can use in skills and in matches.
Know your opponents and what they can do. For example, you would be able to impede a 2BC by only hitting one flag, then using your other on another column.
Also, a flywheel has variable speed, and therefore variable shot distance. I would definitely use this to your advantage.
