What should we do to our robot’s fly wheel to improve the speed and accuracy?
Speed=Higher gear ratio
Accuracy=Even contact surfaces and compression ratios
If you have a flywheel that can make the distance, most of the rest of the work that you have to do it coding, search the forums for PID or TBH, there have been many posts on it by this point. Good luck
I fully agree with that – once you get the hardware aspect of your flywheel(s) finished, getting a speed controller on there like PID or even simpler controller, such as a bang bang, makes a huge difference with the accuracy and fire rate of the wheel.
