Can you make a free spin mecanum drive?
If yes, then how?
please explain further, like on “free spin” do you want the drive base to have no motors?
Do you mean one that has low friction?
Screw Joint, search it there are about at least 20 tutorials.
As I recall all four wheels in a mecanum drive need to have power applied. I think if you had unpowered front wheels and powered rear wheels, it would be just a two wheeled drive. The mecanum wheels are not going to be much of a benefit.
They might be referring to the rollers spinning freely. If that’s the case, then they’re referring to standard mecanum drive.
yeah, I mean I don’t really know what they mean about “free spin” maybe like low friction or smth.
all four of the different directions havre to have motors, however, this is not the case with 8 wheel mecum drives,
I guess that is really a thing, so add me to one of the 10,000
But go big or go home, here is more configs and there is even a 24 wheel one.
From a Chief Delphi thread is these words of wisdom
If you mean a screw joint, then yes, you can just have it be driven by a separate gear. You will need to use the smaller 2in mechanums, since the 4in ones are designed to fit a low-strength axle (smaller than the screw used)
