If you arnt using a slip gear switch to one as it reduces friction and increases launching distance. we are using 2 motors with no gearing. and we shoot full field.
How far do you pull back, I am using about two racks also I think I maybe using too many teeth on the slip gear. How many did you leave and how many did you shave?’
Lastly, how many rubber bands have you been using on each side and what size?
we are using 3 racks. 6-7 teeth of of a 36 tooth gear. i believe we have 3 elastics on each side. the larger ones. i believe #64? correct me if im wrong.
I use a 36 tooth gear with 6 teeth shaven off.
2 #64 elastics on each side for a total of 4.
I find that one of the most important parts to getting full court shots is to have it barely contact the ball.
We have it stretched 6", and then an other 3" with the pullback, and it just hits the ball a little bit.
About 30˚works for us.
I believe that I am having a similar problem. I am using 3 torque motors with 3 #64 rubber bands on each side. We have it connected to a 36 tooth gear with 7 teeth shaved off and it is at a fairly high angle. But we are only able to make it half way across the field. Is the angle the issue? I ask this because it seems to go up more then forward. We’ve been tuning it for quite a while and can’t seem to get it right. Will post pictures when possible. Any suggestions?
