Fully built skyrise sway?
Has anybody played around with a fully built skyrise field? We have the kit, but don’t have it attached to the field. My base is on carpet, so there’s a whole lot of sway in it’s currently location on the carpet when it is built. I know it’s bolted on to the field which should significantly reduce sway. So, when when the skyrise is completely built and bolted on to the field, have you observed any sway?
My team got our field about a month ago and with the Skyrise fully built I have observed no sway at the bottom at the top if you push it will sway a little.
Not much sway at all for us, a tiny bit if it is fully built. But the sections lock together quite well.
Thanks, these were the answers I was looking for.
