#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition) \
do { \
wait(5, msec); \
} while (!(condition))
#define repeat(iterations) \
for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
controller Controller1 = controller(primary);
motor leftMotorA = motor(PORT16, ratio18_1, false);
motor leftMotorB = motor(PORT15, ratio18_1, false);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB);
motor rightMotorA = motor(PORT14, ratio18_1, true);
motor rightMotorB = motor(PORT11, ratio18_1, true);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
motor rollertest = motor(PORT7, ratio18_1, false);
motor flywheel = motor(PORT4, ratio18_1, false);
motor intakemoment = motor(PORT3, ratio18_1, false);
led endgame = led(Brain.ThreeWirePort.D);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1LeftShoulderControlMotorsStopped = true;
bool Controller1RightShoulderControlMotorsStopped = true;
bool Controller1UpDownButtonsControlMotorsStopped = true;
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_function_Controller1() {
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
if(RemoteControlCodeEnabled) {
// calculate the drivetrain motor velocities from the controller joystick axies
// left = Axis3 + Axis1
// right = Axis3 - Axis1
int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
// check if the value is inside of the deadband range
if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
// check if the left motor has already been stopped
if (DrivetrainLNeedsToBeStopped_Controller1) {
// stop the left drive motor
LeftDriveSmart.stop();
// tell the code that the left motor has been stopped
DrivetrainLNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the left motor nexttime the input is in the deadband range
if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
// check if the right motor has already been stopped
if (DrivetrainRNeedsToBeStopped_Controller1) {
// stop the right drive motor
RightDriveSmart.stop();
// tell the code that the right motor has been stopped
DrivetrainRNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
// only tell the left drive motor to spin if the values are not in the deadband range
LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
LeftDriveSmart.spin(forward);
// only tell the right drive motor to spin if the values are not in the deadband range
RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
RightDriveSmart.spin(forward);
// check the ButtonL1/ButtonL2 status to control rollertest
if (Controller1.ButtonL1.pressing()) {
rollertest.spin(forward);
Controller1LeftShoulderControlMotorsStopped = false;
} else if (Controller1.ButtonL2.pressing()) {
rollertest.spin(reverse);
} else if (!Controller1LeftShoulderControlMotorsStopped) {
rollertest.stop();
// set the toggle so that we don't constantly tell the motor to stop when the buttons are released
// check the ButtonR1/ButtonR2 status to control intakemoment
if (Controller1.ButtonR1.pressing()) {
intakemoment.spin(forward);
Controller1RightShoulderControlMotorsStopped = false;
} else if (Controller1.ButtonR2.pressing()) {
intakemoment.spin(reverse);
} else if (!Controller1RightShoulderControlMotorsStopped) {
intakemoment.stop();
// check the ButtonUp/ButtonDown status to control flywheel
if (Controller1.ButtonUp.pressing()) {
flywheel.spin(forward);
Controller1UpDownButtonsControlMotorsStopped = false;
} else if (Controller1.ButtonDown.pressing()) {
flywheel.spin(reverse);
} else if (!Controller1UpDownButtonsControlMotorsStopped) {
flywheel.stop();
// wait before repeating the process
wait(20, msec);
return 0;
task rc_auto_loop_task_Controller1(rc_auto_loop_function_Controller1);
#pragma endregion VEXcode Generated Robot Configuration
// Include the V5 Library
#include "vex.h"
// Allows for easier use of the VEX Library
competition Competition;
float myVariable;
// "when autonomous" hat block
int onauton_autonomous_0() {
// auton-fix-work
// apparently works? new tests + rollerchange needed
rollertest.setVelocity(100.0, percent);
intakemoment.setVelocity(100.0, percent);
flywheel.setVelocity(100.0, percent);
Drivetrain.setDriveVelocity(100.0, percent);
Drivetrain.setTurnVelocity(100.0, percent);
Drivetrain.setStopping(coast);
Drivetrain.driveFor(forward, 15, inches);
Drivetrain.turnFor(right, 90, degrees);
Drivetrain.driveFor(forward, 5, inches);
rollertest.spinFor(forward, 90, degrees);
// velocity tweak/less drive?
return 0;
// "when driver control" hat block
int ondriver_drivercontrol_0() {
//tweak velocity?
//ghengis-notcode
Brain.Screen.drawCircle(0, 0, 10);
Brain.Screen.setPenColor(red);
Brain.Screen.setFont(prop60);
Brain.Screen.print("Nice");
Brain.Screen.setPenColor(yellow);
Brain.Screen.print("Going,");
Brain.Screen.newLine();
Brain.Screen.setPenColor(green);
Brain.Screen.print("Ghengis");
Brain.Screen.setPenColor(cyan);
Brain.Screen.print("!!");
Brain.Screen.setPenColor(white);
Brain.Screen.print("Roger moment");
//pneumatics
while (true) {
if (Controller1.ButtonX.pressing()){
endgame.on();
else {
endgame.off();
wait(5, msec);
return 0;
void VEXcode_driver_task() {
// Start the driver control tasks....
vex::task drive0(ondriver_drivercontrol_0);
while(Competition.isDriverControl() && Competition.isEnabled()) {this_thread::sleep_for(10);}
drive0.stop();
return;
void VEXcode_auton_task() {
// Start the auton control tasks....
vex::task auto0(onauton_autonomous_0);
while(Competition.isAutonomous() && Competition.isEnabled()) {this_thread::sleep_for(10);}
auto0.stop();
return;
int main() {
vex::competition::bStopTasksBetweenModes = false;
Competition.autonomous(VEXcode_auton_task);
Competition.drivercontrol(VEXcode_driver_task);
// post event registration
// set default print color to black
printf("\033[30m");
// wait for rotation sensor to fully initialize
wait(30, msec);
