I’m currently trying to CAD a DR4B in Fusion 360. In the design, there are 2 parallel C- channels connected by a stand-off. How do I joint the standoff to the C-channel. I have tried using project geometries to have a center reference point on each of the holes, but the sketch made from projecting the geometry does not move with the C-Channel and does not joint to the right place.
you can
- offset one of the components in joint commend
- create a joint origin at the center of a c channel hole
Start watching at 20:05 in this video.
Use joint and select two points on either object to joint them. Then change the x, y, and z coordinates to make them line up
