Gear help needed!
Hi everyone!
I keep noticing teams using external gear ratios of 25:1 on there robots. I have been trying to figure out how this is done; however, none of them have worked. Can someone please help? Thank you in advance.
5:1 x 5:1 = 25:1
So using teeth how would that work.
Ex. 80 tooth connected to a 60 tooth on the same shaft with 12 tooth…
Thanks for your fast response
This is as good of a visual representation as I can give you right now.
(driven gear) 5 : 1
_________________5 : 1 (output gear)
I think I understand this.
I’m guessing a 12 tooth driving a 60tooth and then that again connected back to it.
5 : 1 . |
| . 5 : 1 (output)
This may better relay the design. 5 is driving 1 twice (those vertical lines are the axles).
Thanks for your help. That makes a lot more sense
If you go on YouTube and search compound gearing, you can find many vids on how they work.
