Gear ratios
What would be the best gear ratio for going up a 34 degree angle on wood? Doing this to see which ratio is the best for torque. Thanks
I’m moving this to the general forum so the community can help you.
Depends on the weight of whatever is being moved and the radius of the wheels.
And how many motors you are using, coefficient of friction of the wood and tires you use, how many wheels you use, if you actually want it to go fast etc. Any ratio that is more torquey than 1:1.6 could be considered “best for torque”, it just depends on how much speed you want it to have as well.
