I just received Gen2 kits to replace our Gen1 kits. I charged all batteries in controllers and brains. I then paired brains and controllers. I connected the brains to the laptop to check firmware status. Brains and controllers connect without an issue and firmware was confirmed up-to-date.
Problem:
After downloading and running a simple one line project file a few times I get stuck where the system says “Loading Python System Files” or if I don’t get that message I simply can’t run the program I just downloaded into the brain. The brain and VECcode App freezes and I have to pull the battery, kill the app and start over. This happens if I’m connected either directly via the USB cable or wirelessly via USB cable to the controller.
I’m using a new Windows 11 HP laptop.
I found one thread in the V5 Tech Support that sounded similar but no solution was ever posted. Appreciate any help!
