Geometry Software - Inventor-like Capabilities?
Hey all, it’s been a few months since I’ve been on.
I’ve been searching for a geometry program that allows me to have some of the same functionality as the sketch editor in Inventor so that I don’t have to open a fully fledged, bulky 3D application to do 2D geometry. https://6k7frw.bn1.livefilestore.com/y2pEWFzWAIIHszQSXDUHAxsOvWSsb9-xuC6GPpExc4p253LhklfjT5pDVmEfcYsempgl8AzvLDWGPihW6hg1ZQvRtnk9CwVS3wg25Vy3rF8op4/Geometry%20Software.png
The functionality I’m talking about is being able to create sketches and edit certain parameters (i.e. the angle in above picture) and have the rest of the model react and have the same non-driven dimensions.
I haven’t been able to find anything definite, does anybody know of any good software?
AutoCAD LT might be good for you.
~Jordan
I’m not sure if this program has your desired functionality, but I think you might find some use in it. Plus, its indie!
Linkage was kinda sorta what I was looking for, but not exactly. Regardless, I like it for demonstration purposes and I’ll continue to use it.
I did however find AutoCAD Mechanical, which is pretty much Inventor sketch mode, minus Inventor. I don’t know how I didn’t figure this one out earlier, but if anyone ever stumbles upon this thread: this is probably what you want. It’s available for free for students @ students.autodesk.com
I’m sure AutoCAD LT has the same functionality, but I don’t have nearly a grand to toss around :smiley:
I realize you’ve found a solution but I’d just like to add my 2 cents.
You’re pretty much looking for a 2D CAD program (that’s what the sketch mode IS.) AutoCAD would be the AutoDesk version of this but it’s a tad pricey. You may want to take a look at a free alternative like LibreCAD (which I’ve never actually used.)
Almost everyone here should qualify for the Autodesk Educational Portal which has a huge list of free software, many of which are applicable in this case…
AutoCAD for Mac
Autodesk 3ds Max
Autodesk 3ds Max Design
Autodesk Alias Automotive
Autodesk Alias Design
Autodesk AutoCAD
Autodesk AutoCAD Architecture
Autodesk AutoCAD Civil 3D
Autodesk AutoCAD Electrical
Autodesk AutoCAD Map 3D
Autodesk AutoCAD Mechanical
Autodesk AutoCAD MEP
Autodesk AutoCAD P and ID
Autodesk AutoCAD Plant 3D
Autodesk AutoCAD Raster Design
Autodesk AutoCAD Structural Detailing
Autodesk Ecotect Analysis
Autodesk Fusion 360
Autodesk Green Building Studio
Autodesk Impression
Autodesk InfraWorks
Autodesk Inventor Professional
Autodesk Inventor Publisher
Autodesk Maya
Autodesk MotionBuilder
Autodesk Mudbox
Autodesk Navisworks Manage
Autodesk Quantity Takeoff
Autodesk Revit
Autodesk Revit Architecture
Autodesk Revit MEP
Autodesk Revit Structure
Autodesk Robot Structural Analysis Professional
Autodesk Showcase
Autodesk Sim 360 Pro
Autodesk Simulation CFD
Autodesk Simulation Mechanical
Autodesk Simulation Moldflow Adviser Ultimate
Autodesk Simulation Multiphysics
Autodesk Smoke
Autodesk Softimage
Autodesk T_Splines Plug_in for Rhino
Autodesk tsElements Plug_in
Autodesk Vault Basic Server
Autodesk VRED Professional
Seriously guys it’s like Christmas here, go sign up and get cracking! -Cody
