Getting 2 functions to run at the same time?
Unless the ROBOTC VM is doing something strange, declaring a function-local variable as
static
will (by the C/C++ standards, respectively) preserve their values between calls to the function they are declared in (IOW, their lifetimes are extended to the program’s lifetime).
What about the case here, where a method is passed a struct, and it is necessary for the values that are changed during that method to be preserved? What variable would be needed to be declared static?
In this case, I think the code you posted above is fine. Static locals would usually be used to preserve primitive values. For example, a task that continually polls an ultrasonic sensor might want to keep the last valid value in case the ultrasonic sensor times out.
I was speaking to “automatic” variables, not static.
Ah, thus my confusion.
That being said, I don’t see where
auto
variables we’re being discussed (indeed, does ROBOTC even support the
auto
type?)-- unless you meant something other than the type inference keyword from C++?
Ah I see, thank you.
However, I note that
Anyway, to avoid getting further off-topic: I believe the OP’s question was answered, no?
