Getting PID Gains to put in the OkapiLib Gains
Hello,
In OkapiLib, in order to use the PID feature of the Chassis Controller, you need to specify gains with the withGains method in the builder.
std::shared_ptr<OdomChassisController> chassis = ChassisControllerBuilder()
    .withMotors(20, -11, -12, 19) // left motor is 1, right motor is 2 (reversed)
    .withGains(
        {0.001, 0, 0.0001}, // Distance controller gains
        {0.001, 0, 0.0001}, // Turn controller gains
        {0.001, 0, 0.0001}  // Angle controller gains (helps drive straight)
    // green gearset, 4 inch wheel diameter, 11.5 inch wheelbase
    .withDimensions(AbstractMotor::gearset::green, {{4_in, 15.75_in}, imev5GreenTPR})
    .withOdometry() // use the same scales as the chassis (above)
    .buildOdometry(); // build an odometry chassis`
Where can I get these gains from? Or how do I measure them?
Afaik, you tune the gains yourself with little more then trial and error.
So do I just put random numbers until it drives the right distance & turns the right amount?
Thats… certainly one way to do it.
But there are other and better (I think) ways to tune a PID controller:
