There seem to be a few general types of robot that are being successful this year. I was wondering what you all thought.
Type 1: Roller/dumper. Probably the best example is 254a. A simple L-shaped basket with some kind of roller that pulls balls into the basket and then dumps them over the back. Typically holds 2-3 medium balls.
Type 2: Flipper/dumper. Lots of robots like this. Some kind of fork or spatula on an arm that flips balls into a basket, which then dumps over the wall. Typically holds five or more medium balls.
Type 3: Belt lift/dumper. Uses either single row or double row of belts lifting balls into a basket which dumps. Good example of this is 2Z from Gladstone in BC. Typically holds five or more medium balls.
Type 4: Ball cage/4-bar link. Uses rollers or belts to pull balls into a cage, which is then lifted in the air using a 4-bar link. The rollers or belts reverse to score. 1107A from Cambie in BC is a great example of this strategy, and they can score small balls into the goals where they are locked up. This could be a game-changer at Worlds in Elimination matches. Typically hold 2-4 medium balls.
Type 5: Catapult/pitcher. Uses stored energy in rotating wheels, latex bands or compressed air to loft one or two medium balls over the wall. 10Z and two robots from Georgia are notably successful catapults (that I’ve seen).
Type 6: Clawbot. Uses a gripper to pick up and score one ball at a time.
A whole lot more approaches than last year! What do you think will be successful at worlds? I can tell you that Exothermics teams have been changing their approaches over the course of the season. As of today, we have two 4 type 1, 2 type 2, 1 type 3, 2 type 5, and one type 2 variant. In November we had more type 2s than anything else.
