I got the kit today and I think I am missing a plug for the reservoir and the Schrader Valve here is a picture of everything laid out http://i.imgur.com/LQuyxoN.jpg.
Here is the packing slip if anyone cannot see all the pieces in the picture http://i.imgur.com/TmW7Kp5.jpg.
The tire pump fitting is the schrader valve, I see that. What do you mean by the “plug” for the reservoir? I see one installed in the reservoir already, the tire pump fitting goes in the other end.
Ohhhh, thank you so much, the picture I was looking at showed two of the plugs and a different type of tire pump fitting and I thought I was missing some pieces. Thanks again!
I can’t say for sure, it’s hard to see in the picture, but you are probably ok. Connect everything together and see if it all works. If there is a problem vex support will sort it out for you.
The kit was changed slightly some time ago. It used to have the plug to close it on one end and the schrader valve separate attached to the hoses. What you have now is correct, with the hose on one end of the tank and the tire pump fitting on the other.
