The VEXAI field setup (where the GPS sensor originated before spilling into VRC) comes with white film over the lexan panels that is supposed to stay white. The new plastic field with the imprinted code strip is also white.
My question(s) is does the white wall provide any advantage to the system over the clear wall? Does the b/w camera pick up noise through the clear poly? The VRC rules simply state for skills: “the VEX GPS code strip must be installed on the field” and there is no mention of clear/white walls anywhere (I hope I didn’t miss anything). If one is to host an event, will people get pissed if the walls are not white (or viceversa, sorry have no experience with the GPS sensor and its quirks). Did anyone test with clear wall and white wall and noticed any critical differences?
