Gyro Code
How would I create a gyroscope turning code? Would I have to use a PID loop like in EDR or does VCS have a way to do it easily?
Check here
(sorry… every time I see someone posting about their gyro, all I can think of is a sandwich)
gyro
I know… I know… cue the discussion on whether its a sandwich!
The options from VCS for the gyro are very limited. For one it resets once you complete a 360. To take full advantage of gyro I would recommend using the raw data. You will have much more control and accuracy but it will take awhile to program the code. You could use the degrees or percent but from my testing it is not as accurate as the raw data.
1069B - Argonauts
