Hello, I have a gyro y-axis. As I was trying to use it with EasyC , it did not work. Neither the “gyro input” function(built in) or just taking a regular input signal. Does somebody know how can I work with the gyro?
What do you mean by gyro y-axis? You have it mounted on the robot parallel to the ground, yes?
I just finished this blog post that’s basically a brain dump of everything I know about the gyro, and everything I could dig up. I hope you find it helpful. http://renegaderobotics.org/getting-started-with-the-vex-gyro-sensor/
