Does anyone have a PID for the drive train using gyro?
Yes, essentially it’s the same like using encoders but depending on how the gyro is tuned; you’ll have to tune your constants differently, here’s something.
int lastError;
double kP, kI, kD (set these of course; but you will need to tune them)
int current = gyroValue
int error = error - current;
//calculate integral
int integral += error;
//calculate derivative
int derivative = lastError - error;
lastError = error;
//all together
motorSet(error*kP + integral*kI + derivative*kD);
It’s really the same as using encoders or any other sensor, just recognizing the scaling of it; and use the motorSet for some to be positive and others to be negative so that the robot actually turns.
Scroll down to the “Resources” section of this article for some links & info on gyro PID:
https://renegaderobotics.org/pid-resources/
This other article has lots of other gyro information:
https://renegaderobotics.org/getting-started-with-the-vex-gyro-sensor/
If you like dealing in encoder clicks, you can just use one of the available encoder-based PID controllers. (This one by @jpearman, for instance: https://vexforum.com/t/a-pid-controller-in-robotc/20105/1 )
Drive one side of the chassis as the master, calculate the PID error on the other side. Use the gyro rotation angle by turning it into a lag or lead on the slave side.
The lag or lead distance of the slave side is:
2 * wB * sin (.5 theta)
where:
- wB is the wheel base, or the measure from the center of the left side wheels to the center of the right side wheels, and
- theta is the angle measured by the gyro
To work in quad encoder clicks, you can convert this distance into clicks by noting that inches per click can be calculated with:
(Diameter in inches *Pi)/360 clicks
As a quick calculation, assuming exact 4 inch diameter wheels, I calculate that there are .035 inches/click. Using the first equation above and assuming 15 inches between centerline of the two wheel sides, I calculate there are 2 * 15 inches * sin(.5 deg), or .26 inches of lag or lead per degree of turn.
So, (.26 clicks/deg) /(.035 in/click) gives 7.4 clicks/degree
Since the gyro can measure and report tenths of degrees, this means the smallest lag or lead you can work with is .74 clicks/tenth degree.
So you can read the gyro, decide based on the sign (positive or negative) of the turn angle whether you’re dealing with a lag (slow slave side) or lead (fast slave side) and convert the angle into a number of quad encoder clicks to use as your PID error.
This is just one way to think about the problem, but it works well if you already have wrapped your head around quad encoder PID.
I actually just keep my turning PID going all the time and its value is added on top of the values for both sides of the drive while driving straight. Then, I do some arithmetic to make sure it doesn’t get maxed out at 127 (the higher power will be 127, the other side will be the correct amount slower). This seems to work pretty well; we’ve managed to get mobile goals after being thrown 20 degrees of by weird collisions with cones, and it gives me much more peace of mind in believing our autonomous will be consistent. It also allows us to be faster, since I don’t have to make sure the turns are perfect when the drive will compensate a little bit later. We are currently able to stack two cones on a mobile goal and place it in the 20-point zone, hoping to expand that ability to three before this weekend. This is just one different way to look at it; whatever works for you is great, too!
