Gyro Stabalization Help
Hi,
I have a pretty basic bot (Imagine a clawbot but a platform instead of a claw) that I’m attempting to use a code that would allow the platform portion to essentially act as a tank gun stabilizer, keeping it at a level position while i move the entire arm up and down. I have been trying to use a gyro but cannot figure it out, so have made a makeshift code:
int main() {
vexcodeInit();
GyroA.resetAngle();
GyroA.calibrate(0);
Motor6.setBrake(hold);
Motor3.setBrake(hold);
Motor8.setBrake(hold);
I’m still pretty new to using text code so any help would be appreciated.
Just build a 4bar
Was going to, but we don’t have enough time or resources anymore.
Could you send a picture if the end of your 2 bar?
Yes, next time i have it I’ll take a photo
7A42B761-74B8-44C9-ABB4-CECC0067F4CE
Where is the gyro?
Instead of a gyro, try to make a 4 bar lift. It will accomplish the same task without using a gyro. Here is a vexforum post explaining them: How to make a four bar lift
You can’t see it in this photo sorry, but it’s on the left side of the hand covered by the motor and wheel
I am not near a computer right now, I will give you some examples when i am.
Which ones are motor 3, 6, and 9?
Which motor is attached to the tilting gear on the platform
Motor 6 is the hand, the other two are to lift the arm
