Half-cut 3 Inch Flex Wheels
Good Afternoon,
I am getting some new 3 in. flex wheels from a local team soon for my intake hooks, but they are the full sized 1 in. wide. I would like to cut them to be 1/2 in. wide, because that seems to be better for this usage. The only materials we have to cut things are a dremmel and a hand saw. Any advice?
Thanks!
Will
15800A
Atticus
Since the rubber of the flex wheel is so soft, my team has had the best luck using abox cutter with the blade extended ~2 inches and some sort of half inch thick guide to run the knife along.
you’d definitely be better off with a thin, sharp knife than a saw or something spinning.
Hope this helps
Awesome, thank you for the specificity.
