The catapult is randomly shooting up when not not needed.
Make sure the ratchet and pawl assembly is correct and everything is snapped in tight. Just a little offset will allow it to slide by.
So my ratchet and pawl assembly looks fine. Could it be a programming error.? My coach assembled/programmed it for a demonstration robot for my team.
Could be. Can you get your coach to post the code / let you post the code for us to look at.
Our team had an issue with the mechanism slipping. Adding another rubber band fixed the issue.
CAn you show us some pictures of your mechinism?
It’s the mechanism that is on the instructions. I don’t know if that helps.
Okay I will go ahead and ask him.
