Hello,
I have tried programming my gyro to reset back to 0, but when I run the program in my robot, it ends up spiking up instead of resetting?
Any thoughts?
This is my code:
// VEX IQ C++ Project
#include "vex.h"
#include "math.h"
using namespace vex;
//#region config_globals
vex::brain Brain;
vex::motor leftMotor(vex::PORT1);
vex::motor rightMotor(vex::PORT3, true); // Reverse Polarity
vex::gyro jyro(vex::PORT5);
vex::bumper bumper(vex::PORT9);
//#endregion config_globals
void Display()
while(true)
Brain.Screen.printLine(1, "Gyro : %f", jyro.rotation(deg));
Brain.Screen.clearScreen();
void TurnLeft(int distance)
jyro.resetRotation();
while(jyro.rotation(deg) < distance)
leftMotor.spin(reverse);
rightMotor.spin(fwd);
leftMotor.stop(hold);
rightMotor.stop(hold);
int main(void) {
// Start here
thread t(Display);
jyro.startCalibration();
while(jyro.isCalibrating())
this_thread::sleep_for(3000);
TurnLeft(90);
Thank you!
I don’t have any ideas on how to help with this, but if you posted your code or made a viewable copy in robot mesh, I’m sure lots of other people could help.
I totally forgot about it! Thanks a lot for reminding me!
I don’t really understand C++, so I might be wrong here, but it looks like you reset the gyro at the start of the TurnLeft function instead of at the end.
What kind of values is it spiking to? Around 0-360 or arbitrarily high?
I was thinking the same thing. Also you say you are turning left but your inequality and motor directions would suggest that you want to go right. That will get super confusing down the road and will often cause your robot to spin indefinitely or not at all.
That would be a good idea, but I don’t want to reset it at the end, because I want to ensure that the Gyro is at 0 when the functions begins so that I get it more accurate turns.
It spikes to the 3000 mark
Yes, sorry. I just fixed my code, I did not realize it as I was typing it over
Well there goes my guess. Could be that it is a hardware issue. Have you tried using another gyroscope? Also is all of your firmware up to date? Does it do this if you reset your gyro before running your function because if it does it is likely not a problem with your code and some other issue.
Well, the thing is that I work for a Robotic institution, so the same thing happens in classes where we have 12 robots at one time. Yes, they were updated to the latest version. And we also calibrated our gyros during the beginning of the program.
