Header files in PROS
So I have a weird problem with PROS for V5. I am trying to use header files to use a certain function (initComplete()) I wrote in one file (joystick.cpp), and access it in initialize.cpp. joystick.cpp has an accompanying .hpp that also has the function defined, and everything is linked through main.h. Whenever I try to compile it, PROS yells at me for “use of undeclared identifier ‘initComplete’”
Here’s my code:
main.h
 * \file main.h
 * Contains common definitions and header files used throughout your PROS
 * project.
 * Copyright (c) 2017-2018, Purdue University ACM SIGBots.
 * All rights reserved.
 * This Source Code Form is subject to the terms of the Mozilla Public
 * License, v. 2.0. If a copy of the MPL was not distributed with this
 * file, You can obtain one at http://mozilla.org/MPL/2.0/.
#ifndef _PROS_MAIN_H_
#define _PROS_MAIN_H_
 * If defined, some commonly used enums will have preprocessor macros which give
 * a shorter, more convenient naming pattern. If this isn't desired, simply
 * comment the following line out.
 * For instance, E_CONTROLLER_MASTER has a shorter name: CONTROLLER_MASTER.
 * E_CONTROLLER_MASTER is pedantically correct within the PROS styleguide, but
 * not convienent for most student programmers.
#define PROS_USE_SIMPLE_NAMES
 * If defined, C++ literals will be available for use. All literals are in the
 * pros::literals namespace.
 * For instance, you can do `4_mtr = 50` to set motor 4's target velocity to 50
#define PROS_USE_LITERALS
#include "api.h"
#include "joystick.hpp"
#include "drive.hpp"
 * You should add more #includes here
//#include "okapi/api.hpp"
//#include "pros/api_legacy.h"
 * If you find doing pros::Motor() to be tedious and you'd prefer just to do
 * Motor, you can use the namespace with the following commented out line.
 * IMPORTANT: Only the okapi or pros namespace may be used, not both
 * concurrently! The okapi namespace will export all symbols inside the pros
 * namespace.
using namespace pros;
// using namespace pros::literals;
// using namespace okapi;
 * Prototypes for the competition control tasks are redefined here to ensure
 * that they can be called from user code (i.e. calling autonomous from a
 * button press in opcontrol() for testing purposes).
#ifdef __cplusplus
extern "C" {
#endif
void autonomous(void);
void initialize(void);
void disabled(void);
void competition_initialize(void);
void opcontrol(void);
#ifdef __cplusplus
#endif
#ifdef __cplusplus
 * You can add C++-only headers here
//#include <iostream>
#endif
#endif  // _PROS_MAIN_H_
joystick.hpp
#ifdef _JOYSTICK_HPP_
#define _JOYSTICK_HPP_
void initComplete();
bool botIsInitialized();
int getDriveControl();
int getTurnControl();
#endif
joystick.cpp
#include "main.h"
Controller master(CONTROLLER_MASTER);
int driveControl = 0;
int turnControl = 0;
bool botInitialized = false;
void initComplete() {
  botInitialized = true;
bool botIsInitialized() {
  return botInitialized;
int getDriveControl() {
  return driveControl;
int getTurnControl() {
  return turnControl;
void joystickFunction(void* param) {
  driveControl = master.get_analog(ANALOG_LEFT_Y);
  turnControl = master.get_analog(ANALOG_LEFT_X);
Task joystickTask(joystickFunction, (void*)"PROS", TASK_PRIORITY_DEFAULT, TASK_STACK_DEPTH_DEFAULT, "Joystick");
initialize.cpp
#include "main.h"
 * Runs initialization code. This occurs as soon as the program is started.
 * All other competition modes are blocked by initialize; it is recommended
 * to keep execution time for this mode under a few seconds.
void initialize() {
	lcd::initialize();
	initComplete();
 * Runs while the robot is in the disabled state of Field Management System or
 * the VEX Competition Switch, following either autonomous or opcontrol. When
 * the robot is enabled, this task will exit.
void disabled() {}
 * Runs after initialize(), and before autonomous when connected to the Field
 * Management System or the VEX Competition Switch. This is intended for
 * competition-specific initialization routines, such as an autonomous selector
 * on the LCD.
 * This task will exit when the robot is enabled and autonomous or opcontrol
 * starts.
void competition_initialize() {}
So yeah, as far as I can tell there shouldn’t be anything wrong with this, but it still hates me.
RIP me
Here’s your problem:
Should be #ifndef instead of #ifdef. It is treating your joystick.hpp as a blank file because of this mistake.
you can use “#pragma once” to replace “#ifdef
