Help merging code
I need to merge several of my test code projects for my robot into a lcd menu, I want to be able to start a driver control with my battery voltages, and also have it start on that button press(it also needs to work in competition). Any help would be appreciated.
Driver:
#pragma config(Motor,  port2,           lfwMotor,      tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           iMotor,        tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port5,            ,             tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port7,           rfwMotor,      tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port8,           rwMotor,       tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           lwMotor,       tmotorVex393_MC29, openLoop, reversed)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include "Vex_Competition_Includes.c"   //Main competition background code...do not modify!
//                          Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
	bLCDBacklight = true;
  repeat(5)
    displayLCDString(1,0,"Loading 8686K");
    	wait1Msec(500);
     displayLCDString(1,0,"Loading 8686K.");
    		wait1Msec(500);
     displayLCDString(1,0,"Loading 8686K..");
     	wait1Msec(500);
     displayLCDString(1,0,"Loading 8686K...");
    wait1Msec(500);
    clearLCDLine(1);
  // Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
  // Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
//                                 Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
  // Insert user code here.
	AutonomousCodePlaceholderForTesting();  // Remove this function call once you have "real" code.
//                                 User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
	while (true)
			string mainBattery, backupBattery;
	while(true)														// An infinite loop to keep the program running until you terminate it
		clearLCDLine(0);											// Clear line 1 (0) of the LCD
		clearLCDLine(1);											// Clear line 2 (1) of the LCD
		//Display the Primary Robot battery voltage
		displayLCDString(0, 0, "Primary: ");
		sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V'); //Build the value to be displayed
		displayNextLCDString(mainBattery);
		//Display the Backup battery voltage
		displayLCDString(1, 0, "Avg: ");
		sprintf(backupBattery, "%1.2f%c", nAvgBatteryLevel/1000.0, 'V');	//Build the value to be displayed
		displayNextLCDString(backupBattery);
		//Short delay for the LCD refresh rate
		motor[lwMotor] = vexRT[Ch3] / 2;
    motor[rwMotor] = vexRT[Ch2] / 2;
    if(vexRT[Btn6U] == 1)
      motor[iMotor] = 127;
    else if(vexRT[Btn6D] == 1)
      motor[iMotor] = -127;
    else
      motor[iMotor] = 0;
    if(vexRT[Btn5U] == 1)
      motor[lfwMotor] = 0;
      motor[rfwMotor] = 0;
    else if(vexRT[Btn5U] == 1)
    else
      motor[lfwMotor] = 83;
      motor[rfwMotor] = 83;
	  // This is the main execution loop for the user control program. Each time through the loop
	  // your program should update motor + servo values based on feedback from the joysticks.
	  // Insert user code here. This is where you use the joystick values to update your motors, etc.
LCD:
#pragma config(Motor,  port3,           lfwBMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           rfwAMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port5,           rfwBMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port6,           iMotor,        tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port8,           lwMotor,       tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           rwMotor,       tmotorVex393_MC29, openLoop)
const short leftButton = 1;
const short centerButton = 2;
const short rightButton = 4;
int count = 0;
//Wait for Press--------------------------------------------------
void waitForPress()
	while(nLCDButtons == 0){}
	wait1Msec(5);
//Wait for Release------------------------------------------------
void waitForRelease()
	while(nLCDButtons != 0){}
	wait1Msec(5);
void pre_auton()
  //Declare count variable to keep track of our choice
	int count = 0;
	//------------- Beginning of User Interface Code ---------------
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Loop while center button is not pressed
	while(nLCDButtons != centerButton)
		//Switch case that allows the user to choose from 4 different options
		switch(count){
		case 0:
			//Display first choice
			displayLCDCenteredString(0, "Blue Tile");
			displayLCDCenteredString(1, "<		 Select		>");
			waitForPress();
			//Increment or decrement "count" based on button press
			if(nLCDButtons == leftButton)
				waitForRelease();
				count = 3;
			else if(nLCDButtons == rightButton)
				waitForRelease();
				count++;
			break;
		case 1:
			//Display second choice
			displayLCDCenteredString(0, "Red Tile");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 2:
			//Display third choice
			displayLCDCenteredString(0, "Test Blue");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 3:
			//Display fourth choice
			displayLCDCenteredString(0, "Autonomous 4");
			displayLCDCenteredString(1, "<		 Enter		>");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count = 0;
			break;
		default:
			count = 0;
			break;
	//------------- End of User Interface Code ---------------------
task autonomous()
	//------------- Beginning of Robot Movement Code ---------------
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
	//Switch Case that actually runs the user choice
	switch(count){
	case 0:
		//If count = 0, run the code correspoinding with choice 1
		displayLCDCenteredString(0, "Autonomous 1");
		displayLCDCenteredString(1, "is running!");
		wait1Msec(2000);						// Robot waits for 2000 milliseconds
		// Move forward at full power for 3 seconds
		break;
	case 1:
		//If count = 1, run the code correspoinding with choice 2
		displayLCDCenteredString(0, "Autonomous 2");
		// Move reverse at full power for 3 seconds
		break;
	case 2:
		//If count = 2, run the code correspoinding with choice 3
		displayLCDCenteredString(0, "Autonomous 3");
		//Turn right for 3 seconds
		break;
	case 3:
		//If count = 3, run the code correspoinding with choice 4
SensorValue[dgtl1] = 1;
		//Turn left for 3 seconds
		break;
	default:
		displayLCDCenteredString(0, "No valid choice");
		displayLCDCenteredString(1, "was made!");
		break;
	//------------- End of Robot Movement Code -----------------------
task usercontrol()
	while (true)
    else
      motor[iMotor] = 0;
      motor[lfwAMotor] = 0;
      motor[rfwAMotor] = 0;
      motor[lfwBMotor] = 0;
      motor[rfwBMotor] = 0;
    else
      motor[lfwAMotor] = 83;
      motor[rfwAMotor] = 83;
      motor[lfwBMotor] = 83;
      motor[rfwBMotor] = 83;
	  UserControlCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
Not exactly sure what you are trying to do but I will give it a shot.
You could make some functions out of the common tasks like the LCD battery voltage display and call it from user control or autonomous areas.
Once there, you will see the code looks smaller. You can move the functions to another file and #include that file. Stick it in the same directory as the current file so it knows where to load it from. Or leave it in one file, it does not matter that much.
Just remember the compiler is stupid is as stupid does - it reads from the top down so it needs to know about the function before you call it the first time. So define it or declare it up top.
Then once you have cleaned up the code into functions, you can see what you want to do more clearly. Just remember a loop in the function means nothing else gets done sicne control stays there. What you can do to alleviate that is you can set a variable first then call a set of functions to act on the variables.
Or you can look at background tasks. That will take those variables and act upon them in the tasks’ loops. But try cleaning up into functions first. One thing at a time.
I should probably reply before you try too hard, I figured it out last night. What I do need help with is making it so that if I press center button for more than say 5 seconds it will initiate that code, but if I press it for <5 seconds it just selects that for autonomous, or skills, I one of my options dedicated driver testing, aswell as with the battery display and other, I can post that here if you’d like, also sorry for not responding that I fixed it last night, I fell asleep.
Look for the button press, note the time it started in a variable. You could set a timer our use a variable. Your choice.
Now look for a button up. See how long the button was pressed and react accordingly.
Well, its kind of hard to do that, as it will automatically use the waitforpress function to set it up for autonomous and not continue with the sequence of code allowing it to be ran.
give me a second ill post it here.
#pragma config(Sensor, dgtl1,	 Bump,					 sensorTouch)
#pragma config(Motor,	 port3,						rfwMotor,			 tmotorVex393_MC29, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard							 !!*//
int count = 0;
void waitForPress()
	wait1Msec(5);
	wait1Msec(5);
void pre_auton()
	repeat(5)
		wait1Msec(500);
		wait1Msec(500);
		wait1Msec(500);
		wait1Msec(500);
		clearLCDLine(1);
	int count = 0;
	//Clear LCD
	clearLCDLine(0);
	clearLCDLine(1);
		switch(count){
		case 0:
			displayLCDCenteredString(0, "Driver Control");
			displayLCDCenteredString(1, "< Start >");
			waitForPress();
				waitForRelease();
				count = 3;
				waitForRelease();
				count++;
			else if(centerButton)
					wait1Msec(5);
						else
							motor[iMotor] = 0;
						else
			break;
		case 1:
			displayLCDCenteredString(0, "Skills");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 2: //Display third choice
			displayLCDCenteredString(0, "Tile Left");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count++;
			break;
		case 3: //Display fourth choice
			displayLCDCenteredString(0, "Tile Right");
			waitForPress();
				waitForRelease();
				count--;
				waitForRelease();
				count = 0;
			break;
		default:
			count = 0;
			break;
task autonomous()
	clearLCDLine(0);
	clearLCDLine(1);
	switch(count){
	case 0: //If count = 0, run the code correspoinding with choice 1
		displayLCDCenteredString(1, "no program!");
		break;
	case 1: //If count = 1, run the code correspoinding with choice 2
		displayLCDCenteredString(1, "is selected!");
		break;
	case 2: //If count = 2, run the code correspoinding with choice 3
		break;
	case 3: //If count = 3, run the code correspoinding with choice 4
		break;
	default:
		displayLCDCenteredString(0, "No Response");
		displayLCDCenteredString(1, "(Default)");
		break;
task usercontrol()
	while (true)
					wait1Msec(1);
						else
							motor[iMotor] = 0;
						else
is there a way to make an if(centerButton) = true for more than 5 seconds have it turn on the code, but if its just a press and is released in less than 5 seconds it chooses the code for the autonomous portion of the match?
what about an if(centerButton) and a wait 5 second, and then have the waitforpress in the else? or would that just always have it for the functions way if it is pressed?
Ok, I have the wait 5 seconds and then activate code function, I just made this:
if)(centerButton)
motor[iMotor] = 127; //this is my intake motor turning on
else
waitForPress();
the only thing that doesn’t work is the just setting the count for the autonomous selection.
im making a dedicated thread for this because this is kinda off topic
Don’t wait for a press, look to see if a press happened and react on the next loop around. Otherwise whatever the previous command for the motors were on everything else will continue to happen (like driving or intakes or whatever was previously turned on)
Have a look at some of the code in this thread, it may give you some ideas.
https://vexforum.com/t/robotc-lcd-autonomous-selection/24818/1
Also, when detecting short/long button presses it’s often the release of the button that triggers the action, not the press. Same is true when using a mouse, try that with the “Post a Reply” button below, notice how it’s the mouse release that triggers the action not the mouse press.
