HELP! might fail class...
can i get a wiring diagram for a robot with two motors and a camera? pleeasse?
I normally don’t respond to things like this…
but I’ve been (under) impressed with the number of recently posted bad questions
HELP! might fail class … is a really bad title. I get the help part. I don’t get the might fail class part. The body of the note says “can i get a wiring diagram for a robot with two motors and a camera? pleeasse?” Nothing about a class, or which class or fail. A better title would have been “How do I wire a camera to the VEX”.
Which camera? The CMU camera? A simple search would have found this post about the CMU camera. It may not have been as helpful as this Chief Delphi post that has lots of extra details.
Motors plug into the motor ports. Should be clear since the ports are labled Motor.
I would have worded the question: “Can someone please post a wiring diagram for a robot with two motors and a CMU camera?”
Actually I would have googled “Connecting a CMU cam to a VEX” and found links like this one from CMU
Lastly, most of us don’t want to do your homework, so the fail part does not really matter. It’s the same as me writing “Can someone give me plans for a Championship robot”
So the lessons learned are:
– Google first
– Search VEX forums second
– Create a title that is a good summary of your message
– Write a clear message with as much information as possible.
– Spelling and the correct use of capitals impress us.
– Don’t ask us to do your homework.
I did answer your question, the second link is your best resource.
I would like to add that the Vex Inventors Guide shows how to create the Square Bot, which has Two Motors, and Tank or Arcade Control.
