Help needed with the light sensor
I was wondering if there is any way to program the controler to compair two light inputs and move towards the highest one.
A sample program would be nice too :stuck_out_tongue:
Reported.
To answer your question you would want to make two measurements. The first one of the first light source and then another of the second light source. Then you could use an if statement to determine where to go. For example:
if(a>b)
goto light a
if(b>a)
goto light b
i might just be an epic failz after all becuse that is still confusing (im sort of new to programming Vex) i understand how to make it turn when it hits a certain point but other then that im kind of lost.
Here is a short program that should help you along.
You’re never an ā€œepic failzā€ whoever wrote that is whats called a troll. They are people who post things to ā– ā– ā– ā–  others off. Ignore it, the moderators will delete.
LightSensor Choice.zip (1.15 KB)
With a User Name of ā€œU faleā€, what would you expect?? Life is tough enough, with out the Trolls out there that are bored.
There’s another example under the Light Seeker project at this link. It’s not exactly the same as your project, but you can use 2 separate light sensors and eliminate the servo (no need to turn the sensor to 2 positions, since you have 2 sensors.
It’s hard to believe that there are people who would send a reply like that on this forum - I’m glad that you were able to get some help with your project.
Never hesitate to ask for help - we’ve all needed it from time to time. Things can be confusing sometimes, especially when you are just starting out.
So have you got it to work?
A Vexmentor sent me a program and it was helpful in getting it in my head but it dident work so im kind of still working on a program.
And also the guy named Ufail is sort of my classmate who is working on the same project. However trolling is a big thing that is wrong with the internet.
Hey this is tkwire’s other classmate, we’re working on the same project with the light sensor. We are however stuck on the part where we have to make it read and then compare then move towards the brightest light, however what we have managed to do, is have it spin around until it gets a certain light amount. Any help will be appreciated.
Can you guys post your code? That way we can see what you already have an help you move on from there.
i will try im not really sure how so i will post it as a download.
lol so that dident work. [ATTACH]786[/ATTACH]
New Compressed (zipped) Folder.zip (1.22 KB)
Looks like it should work, except that everything needs to be in an endless loop.
#include "Main.h"
void main ( void )
      unsigned int leftlight = 0;
      unsigned int rightlight = 0;
      while ( 1 ) // Loop Forever!!!
            rightlight = GetAnalogInput ( 3 ) ;
            leftlight = GetAnalogInput ( 4 ) ;
            if ( rightlight > leftlight  )
                  SetMotor ( 2 , 0 ) ;
                  SetMotor ( 3 , 0 ) ;
                  Wait ( 200 ) ;
            if ( leftlight > rightlight  )
                  SetMotor ( 2 , 255 ) ;
                  SetMotor ( 3 , 255 ) ;
                  Wait ( 2000 ) ;
            else
See Attached Project.
easyC_light_help-001.zip (1.57 KB)
wow thanks it worked, just added the limit switch bumpers and the ultrasonic and now it’s set to go, thanks for the help that helped me understand it better.
No Problem…
Just remember that when it comes to Programming/Code issues, it really helps to ā€œPost Your Codeā€.
If you have any other questions, just ask… :wink:
Both me and my clasmate would like to thank all of you who helped with our programing and fine tuning.
Hi,
Heres my take:
void main ( void )
int diff;
        // change 10 bit to 8 bit value (also helps reduce noise)
        rightlight = rightlight >> 2;
        leftlight = leftlight >> 2;
        // now you should get +- 255
        diff = left - right;
        // shift the 'center' to 127
        diff += 127;
        // limit the scale to 0 to 255
        if(diff < 0) diff = 0;
        else if(diff > 255) diff = 255;
        // you may need to invert your motors / direction depends on the behaviour
        // motors should turn your squarebot towards the light source.
        SetMotor ( 2 , diff ) ;
        SetMotor ( 3 , diff ) ;
        Wait ( 50 ) ;
Hope this helps, or just take it as something to think about. Not tested but the idea should be there
