Help? Please?
I posted this on the main Tech Support channel and a bunch of people read it but didn’t say anything. So I’m posting it here hoping someone helps. Edit: I guess there really isnt a difference between the two, this pops up on the main one too. Whatever, didn’t mean for it to seem impatient. I thought I was posting it on two channels.
So yesterday I posted my old code for incorporating velocity control into our robot and it was pretty bad, but we got some help and I tried to clean it up. I just want to make sure this works properly, so could someone look over it and give me some pointers?
Thanks, here is the code.
#pragma config(Sensor, I2C_1,   				leftFlywheel,  sensorQuadEncoderOnI2CPort,    , AutoAssign )
#pragma config(Sensor, I2C_2,   				rightFlywheel, sensorQuadEncoderOnI2CPort,    , AutoAssign )
#pragma config(Motor,  port1,           IW1,           tmotorVex393HighSpeed_HBridge, openLoop)
#pragma config(Motor,  port2,           DW1,           tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor,  port3,           DW2,           tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor,  port4,           DW3,           tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor,  port5,           DW4,           tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor,  port6,           flyWheelL1,    tmotorVex393_MC29, openLoop, encoderPort, I2C_1)
#pragma config(Motor,  port7,           flyWheelL2,    tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port8,           flyWheelR1,    tmotorVex393_MC29, openLoop, encoderPort, I2C_2)
#pragma config(Motor,  port9,           flyWheelR2,    tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port10,          IW2,           tmotorVex393HighSpeed_HBridge, openLoop)
static int target;   //defines global variable for target velocity
task velocityControl; //defines velocityControl don't touch this
float FwMotorEncoderGet(int side); // defines the two functions used to calc actual velocity
float FwCalculateSpeed(int side);
void setVelocity(int speed); //function to choose target velocity
task main()  //beginning of driver control
		nMotorEncoder[leftFlywheel] = 0;  //sets the motor encoders to 0 outside of the loop
		nMotorEncoder[rightFlywheel] = 0; //so that it doesn't continually reset
		startTask (velocityControl);	//starts up the velocity control task
			while(1 == 1){
				//dummy text for flywheel
				if(vexRT[Btn8D] == 1 ){
					setVelocity(70);
 				//Intake code
 					 if(vexRT[Btn7L] == 1){
							motor[IW1] = 127;
							motor[IW2] = 127;
						else if(vexRT[Btn7D] == 1) {
							motor[IW1] = -127;
							motor[IW2] = -127;
						else {
							motor[IW1] = 0;
							motor[IW2] = 0;
				//Wheel control
 					 if(vexRT[Btn6U] == 1 ) {
  						motor[DW1] = -75;
  						motor[DW2] = -75;
  						motor[DW3] = -75;
  						motor[DW4] = -75;
  					else if(vexRT[Btn5U] == 1) {
	 						 motor[DW1] = 75;
  						 motor[DW2] = 75;
  						 motor[DW3] = 75;
  					   motor[DW4] = 75;
						else if(vexRT[Ch2] > 15) {
							motor[DW1] = -100;
							motor[DW2] = 100;
							motor[DW3] = 100;
							motor[DW4] = -100;
						else if(vexRT[Ch2] < -15)	{
								motor[DW1] = 100;
								motor[DW2] = -100;
								motor[DW3] = -100;
								motor[DW4] = 100;
						else {
								motor[DW1] = 0;
								motor[DW2] = 0;
								motor[DW3] = 0;
								motor[DW4] = 0;
									//end wheel control
		//end drivercontrol
task velocityControl(){
			float Lvelocity;					//initilizes and calculates
			float Rvelocity;					//left and right velocities
			Lvelocity = FwCalculateSpeed(1);
			Rvelocity = FwCalculateSpeed(0);
			//initilize all the variables needed in PID
			float kp = 0.01; //proportional constant
			float ki = 0.000000; //integral constant
			float kd =0.00; //derivative constant
			float Lcurrent = 0;
			float Rcurrent = 0;//starts with no power
			float Lerror; //current error constants
			float Rerror;
			float integralActiveZone = 2; //integral error accumulates
			float LerrorT; //total error
			float LlastError; //last error recored
			float RerrorT; //total error
			float RlastError; //last error recored
			float Lproportion; //proportion term
			float Lintegral; //integral term
			float Lderivative; //derivative term
			float Rproportion; //proportion term
			float Rintegral; //integral term
			float Rderivative; //derivative term
			while(true){
				//start of PID algorithm loop
				Lerror = target - Lvelocity; //difference between current vs target velocity
				Rerror = target - Rvelocity;
				if(Lerror<integralActiveZone && Lerror !=0){ //active integral zone
						LerrorT += Lerror; //adds error
						else {
							LerrorT = 0;
				if(Rerror<integralActiveZone && Rerror !=0){ //active integral zone
						RerrorT += Rerror; //adds error
				}		else {
								RerrorT = 0;
				if(LerrorT>50/ki){ //caps error at 50
						LerrorT = 50/ki;
			 	if(Lerror == 0) { //if error zero then derivative zero
						Lderivative = 0;
				if(RerrorT>50/ki) { //caps error at 50
						RerrorT = 50/ki;
				if(Rerror == 0) { //if error zero then derivative zero
						Rderivative = 0;
				//A bunch of PID calculations for the left and right sides
								Lproportion = Lerror * kp; //setting proportion term
								Lintegral = LerrorT * ki; //setting integral term
								Lderivative = (Lerror - LlastError)*kd;//setting derivative term
								Rproportion = Rerror * kp; //setting proportion term
								Rintegral = RerrorT * ki; //setting integral term
								Rderivative = (Rerror - RlastError)*kd;//setting derivative term
								LlastError = Lerror; //last error becomes current error for next loop
								RlastError = Rerror; //last error becomes current error for next loop
								Lcurrent = Lproportion + Lderivative + Lintegral; //setting power
								Rcurrent = Rproportion + Rderivative + Rintegral; //setting power
			//take the value from PID and put it into the motors
					motor[flyWheelL1] = motor[flyWheelL2] = Lcurrent; //giving motors power
					motor[flyWheelR1] = motor[flyWheelR2] = Rcurrent;
		wait1Msec(20); //proventing hogging of CPU power
		//end velocity control
//function to set desired speed in program
void setVelocity( int speed ) {
		target = speed; //setss what you put into it as the variable target
//function to get the actual velocity of each side
float FwCalculateSpeed(int side){
		float 		velocity;								//initializes all the variables
    float     delta_ms;
    float     delta_enc;
    float			nSysTime_last = 0;
    float 		ticks_per_rev = 627.2;
    float 		encoder_counts;
    float 		encoder_counts_last;
    // Get current encoder value for a side
    if (side == 1) {
    encoder_counts = FwMotorEncoderGet(1);
		if (side != 1) {
			encoder_counts = FwMotorEncoderGet(0);
    // This is just used so we don't need to know how often we are called
    // how many mS since we were last here
    delta_ms = nSysTime - nSysTime_last;
    nSysTime_last = nSysTime;
    // Change in encoder count
    delta_enc = (encoder_counts - encoder_counts_last);
    // save last position
    encoder_counts_last = encoder_counts;
    // Calculate velocity in rpm
    velocity = (1000.0 / delta_ms) * delta_enc * 60.0 / ticks_per_rev;
    return velocity; //returns the value so that velocity control can store it in a variable
//function to get the value of the motor encoders
float FwMotorEncoderGet(int side) {
		float count; //init variable we store ticks in
		if (side == 1) {												//gets the ticks for one side depending on what you feed into it
		nMotorEncoder[leftFlywheel] = count;
			if (side != 1) {
		nMotorEncoder[rightFlywheel] = count;
		return count;
I don’t see an issue specifically with your code, but I may have looked over something. Is there something about that code specifically that isn’t working? Like, how is your robot preforming compared to how you would like it to preform? That will make it easier for us to make suggestions / fixes.
I haven’t been able to test it yet. I finally got the robot shooting high enough to get full court shots and I didn’t bring the IMEs home with me. So I have to wait until tomorrow to find out if it works properly. I just wanted to know if there were any parts of the code that don’t flow properly. Like if I put all the task calls and the clearing of the Motor Encoders in the right place.
